[email protected]
I put the stock heater control cables in my RV10 and for two fall seasons in a row I had trouble getting my heater control cables working again. I lubed the sheath on the outside with Triflow and got someone to pull on the knob while I pushed on the valve and I finally got them going again. I am thinking of putting in some different control cables. I see ACS has some teflon lined ones that are less likely to set up over the summer. Has anyone used these? Has anyone had similar problems and found a good solution? I believe the Van's supplied ones don't have any lining at all. Just metal on metal with the core riding on the spiral metal sheath.
