For the electronics hobbyists among us... would this be useful in an RV as secondary/backup?
Spankfun 4x4 mm AS3935 Lightning Sensor IC board for 24.95 (need to pair with cheap MCU)
https://cdn.sparkfun.com/assets/learn_tutorials/9/2/1/AS3935_Datasheet_EN_v2.pdf"]AS3935 DataSheet
Features:
Programming is really simple - the hardwired, distance estimation algo simply issues an interrupt on the IRQ pin. Use a connected MCU to provide UI (text on MCU LCD, lights, sounds, etc). SparkFun has ardunio code on GitHub and detailed instructions.
Interference @ 500KHz (may be difficult to shield detector from)
The board is designed for use in diy weather stations.
Features:
- 40km radius range w/accuracy of 1km in 15 steps
- Programmable detection levels/thresholds
- Distance to storm estimation (edge of storm, not lightning event)
- IC-embedded false event rejection algorithm
- SPI programming interface
- Supply Voltage: 2.4V - 5.5V (internal IC voltage regulator)
- Auto IC calibration
- Passive detection of cloud-to-cloud as well as cloud-to-ground
- Built-in antenna (500KHz Resonant Frequency)
- Inductor DC to DC converters absent mumetal shielding on the converters
- smart phone and smatch watch displays (when display is active)
