RV ers around Troy wisconsin
almarsh
Need place to keep 6a on 6/19 thru 6/21/13 first Xc. Fight 42 hrs. Hobbs on 17.5 yr. project
Planning on flying into Troy wisconsin thanks allen.
Al,
I assume you're referring to East Troy (57C.) Can't help with hangar space, but be advised that the main runway is currently closed for repaving and will be for the next several weeks. The grass runway (18/36) is open for now, but will be closed at some point (yet to be determined) to repave the section where the runways cross. Don't want to see you fly in only to be stuck with no open runways.
If you can find space at some other airport nearby, that might be a better option for you.
