24Golf
I have searched here & there with no luck... it is time to install the EGT sensors and can't seem to find the right place. Here is the problem: on Cyl 1 the exhaust turns immediately towards the other side this would allow connection after about 3". On Cyl 3 the welded joint connection starts about 2.0" from the flange and goes down for about 3" to the 5" location. Cyl 2 is straight for 3" then the welded joint takes up the next 3" down to the 6" point. Cyl 4 is straight for 4" the starts a big turn. This is the vetterman exhaust that Vans sends with the 9A FWF kit and will be installed with the Dynon probes. Dynon says to install 2" to 8" from the exhaust flange and all sensors must be the same distance away . There is no common single distance that I can set the probes that would allow for equal temp measurement. You other 9'ers - please help!
THANKS
THANKS
