ron sterba
Was wondering how long is your nose gear leg slot on lower cowl.Having a 3 bladed catto prop I can't slide the lower cowl up and on like when I had the two bladed prop. The two blade can be placed horizontaly and the lower cowl just slips on where as on the 3 blade,,,,,two of the blades are lower thus hindering the slip on of the lower cowling so I have noticed that if I make the gear leg slot longer it would give me the wiggle room to slide the cowl up and in place.
So how long did you make your nose gear slot???
Thanks and always appreciated.
Ron in Oregon
Ron in Oregon
