RV-9A weight
jhphillips
Active Member
I'm considering building 9A with O320 and F/P prop - for anyone with similar configuration - what's the weight on the nosewheel.
For comparison, my 6A with O360 and Hartzell C/S prop weighed 319lbs on the nosewheel.
Thank you.
Last RV-9A I weighed had an O-320, Sensenich metal prop, and here were the weights:
266 lbs on the nosewheel, 34.50" arm
408 & 418 lbs on the mains, 91.88" arms both
(forgot to mention, it was painted, single stage)
Here's data from my RV-9A (no wheel pants or fairings installed). O-320, Sensenich prop.
Nose 267 lbs 34.25" aft of datum 9,144.75 in-lbs moment arm
Right 411.00 90.94 37,375.31
Left 407.00 90.88 36,986.13
Add 13 lbs for the fairings and wheel pants (including lead weight in wheel pant nose cones).
John,
Here are 3 samples from my files.
RV-9A...Sensenich F/P...266# nose
RV-9A...Catto 3-blade....243# nose
RV-9A...MT 2-blade.......302# nose
I have an O320, carb, fp and two batteries.
Nose 280#, 33.69"
Right main 402#, 91.13"
Left main 402#, 91.13"
Ted
http://tc1234c.googlepages.com/
RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, Dual Mag, Sensenich FP
GRT dual DU H1, TT DigiFlight II VSGV, 160 hr Hobbs
N2PZ RV-9A Weight & Balance
After painting, with all the interior installed, and five quarts of oil, the empty weight of my airplane came to 1,184 pounds.
Nose wheel = 310 pounds
Left wheel = 432 pounds
Right wheel = 442 pounds
O-320-D1A with carb
Hartzell Constant speed prop
The Odyssey battery and a car stereo are on the right side. My autopilot servo is out in the left wing just outside of the aileron bellcrank.
Filled with fuel = 1,400 pounds. Look at this page when the final weight and balance was performed with "accurate" scales. http://www.n2prise.org/rv9a165.htm
Jerry K. Thorne
East Ridge, TN
RV-9A N2PZ 223.0 Hobbs hours.
John,
I know you wanted weights with a F/P prop but this information might give some comparision data.
I recently weighed my 9A and I am still having fun playing around with the figures: 0-320 RV-9A weighed on accurate calibrated scales. Including oil, Hartzell C/S, paint/trim, all fairings, Flightline interior and full epoxy prime internally. Only thing to add is the ELT, which I will install in the tail.
Weight 1097 lb.
Weight on nose wheel 288 lb.
Assuming an ELT in the tail and with me as the pilot (167 lb):
Most fwd CG ? full fuel, no passenger or baggage gives a CG 10% aft of the fwd limit and a calculated weight on the nose wheel of 339 lb.
Most aft CG situation I can envisage ? 5 gals fuel, 265 lb passenger and 100 lb baggage gives a CG 83% aft of the fwd limit and a calculated weight on the nose wheel of 233 lb.
Fin 9A Australia (I hope you good USA folk appreciate my efforts to convert from our kgs into your antiquated lbs!!):rolleyes:
