I am working of a RV9A project I purchased. I removed the C-702 FWD Skin clecoed to the WD-716 welded assembly and discovered that the 7/16 tube is cracked at the sixth drilled hole on the pilot side. The cracked hole is at the junction of the tube and the welded gusset.
Is there a fix or repair?
The tip up frame at this point is very floppy and I cannot yet see where the final strength will come from.
Thanks for any assistance.
