I tried to do an airspeed run today (three runs at 0, 180, and 90 degrees). I have finally completed the wheel pants and wanted to see what the change was. I could not fly full throttle because I kept getting prop over speed. I have an RV-9A with a 160 hp 0-320. I am using the Van?s recommended Sensenich fix pitch prop which has an over speed limit of 2600 rpm. At indicated of 162 mph and ground speed GPS of 175 mph the prop would go to 2600 rpm at 6500 ft, 80 OAT and 24 mp. I did the speed runs at 23.4 mp, 2500 rpm and got an IAS of 159 with a TAS of 173. With out the wheel pants I got IAS of 142 and TAS of 164. Same outside air temperature for with and without pants.
Has anyone seen this problem before? Is it typical that the RV-9A can not cruise at full throttle at 6500 ft with a the Van?s recommend fix pitched prop and a 160 hp engine without exceeding the max prop rpm limit?
Comments?
Comments?
