panheadmark
Member
OK, here we go..... first post here, I just started on the fuse of my 9A and am now looking at engine choices, yes I know about the 160 hp "rule"
but after reading what Mahlon Russell of Mattituck Engines said and my limited supply of "fun tickets" this might be the way to go.
www.eaa326.org/Newsletters/eaa326-1-2005.pdf
I'm thinking of using an O-360 with one e and one p-mag and low compression pistons which would put it at 170 hp. The benefits of doing this would be less stress on the engine which should make it last longer, and the ability to run mogas. This still puts me over by 10 hp yes I know, but then instead of sticking a heavy cs prop on the front I would put on one of Cattos 3 bladed smooth running lighter props. It's been said that 3 bladed proppellers aren't as efficient as 2 bladed, maybe not the full 10 hp but you can see where I'm going with this.
The price difference between an O-320 set up with a cs and an O-360 fixed is over 5 grand. I'm having a hard time justifying the cost and maintenance of the 320 when this looks like a much better choice, for me anyway.
Mark Erickson
RV 9A #91317
Fuselage
Minnetonka, MN.
Mark Erickson
RV 9A #91317
Fuselage
Minnetonka, MN.
