Does anyone recall how much of each end of the VA256 hex pushrod they had to cut off to make the proper length? Also , what is the best method to open the exit hole? ie. start with the flap all the way up or midway? The plans call for a total bearing to bearing length of 6 5/8 in. How much bearing thread needs to be sticking out each end of the rod?
Thanks in advance
Oldgeezer
RV9A
Thanks in advance
Oldgeezer
RV9A
