Eriselle
Member
Hi VAF,
I am an owner of an RV-12 SLSA, and I've been waffling on wanting to start an RV-12iS or RV-9A build for months now, and I ended up deciding on the RV-9A. Empennage kit is officially ordered, and I was issued a serial number today, yay! Really exciting stuff. The lead times on the kits looks really good right now too, so hopefully I won't have to wait too long!
I have heard from other builders that later kits in the total build sometimes have things that require you to go back and do modifications to earlier kits that can sometimes be a lot more challenging than if you had done those things up front during the original build of that piece. For example, I've been told that it would behoove me to acquire and install VOR antennas (or at least some portion of that work, such as drilling the holes etc) while I'm building the vertical stabilizer, even though AFAIK the VOR antenna would normally be a later purchase with the avionics components? Not sure if this is different to RV-12iS that actually has a specific avionics kit, versus the RV-9A which AFAIK I'm a bit more on my own for it?
What things about the build do you think I should have completely planned out before I start working on empennage metal? Some things that come to mind are lighting that might be on the empennage (such as a beacon), avionics that would affect the the trimming system and/or autopilot (I'm planning on dual Garmin G3X with navigator for IFR).
Thank you for your advice.
