mculver
Is the hole in the bottom center of the RV-9 VS Rear Spar supposed to be drilled for a bolt? The drawings sort of indicate so; however not with precision. If this hole is supposed to be a bolt, do I drill now, or once in place in the fuselage? Given that the hole was located with CNC equipment, I assume that now is OK.
It appears that the RV-9 VS Rear Spar is the same as in the RV-8, and similar to other models too. However I can't find an answer to my question anywhere.
Also, in the second image I am trying to figure out if the holes with the red arrows pointed at them are part of the VS rear spar, or if they are part of the fuselage bulkhead.
(click on either image for a higer-res version)
![](/proxy.php?image=http%3A%2F%2Fmculver-photos.s3.amazonaws.com%2FDwg6-thumb.jpg&hash=90e06f4caec21c4479c92602fbdc8f0e)
![](/proxy.php?image=http%3A%2F%2Fmculver-photos.s3.amazonaws.com%2FDwg27-thumb.jpg&hash=f112f6566877a78e363119f9b96ffb96)
