Kind of a long post...
I recently finished building my RV-9A fuel tanks.
I started this work knowing that many consider this the most arduous and messy
part of the build.
First off, thanks to all of the builders who have gone before me and have contributed
write ups, posts and pictures about the tank building process on this and other web sites.
It is invaluable to be able to get a mental picture on the steps before you plunge in.
I started by getting all of the ribs and skins prepped. Take off the blue plastic from
the interior of the skins. Smooth out all of the edges with a file, then polish the edges
with a scotchbrite wheel.
Build the cradle. I used some scrap lumber from the wing kit crating.
Leave some space at the bottom of the cradle for the clecos to poke down
from the skin. I cut an area out of the middle of the base in order to be able to
get the rivet gun to angle up to the rivets on the nose of the tank.
Straightened all of the ribs by fluting. As long as the line of prepunched
holes is fairly straight, that is good enough.
As many have said, the first time clecoing the skin to the ribs is very tough.
The tank skins are thick and the bends seem wrong, but as you wrap the skin
from the nose around to the aft sides, things start to line up. I ended up
rounding out and smoothing the curvature of the small nose rib flanges on
the tank ribs with some sand paper. This made the skin fit easier.
Make all of the stiffeners. One of the stiffeners is cut shorter, and make sure
to make a left and a right version of the short stiffener.
Match drilling all of the parts helps everything start to align better.
I posted a tip about centering the fuel drain. I also sprung for the deluxe fuel caps.
Very pricey, but wow, they work like you would expect, unlike the stock
caps which seem to require brute force and a pry bar to open and close.
I took my soldering iron to all of the rivet lines, drain and filler cap on the
outside of the skin to remove the blue plastic. Deburr everything.
Countersink the rivet holes for the back baffle. You don't want to go too
deep, because the tank skin isn't that thick, but remember when you seal
these there will be sealant in there. After I completed the tank, my line of
skin/baffle rivets was just a little bit proud of the skin surface compared to
the dimpled rivets that used the tank dimple dies.
Clean the interior with acetone, then tape off the surfaces where the
stiffeners and rib flanges will join. Scuff both the ribs, stiffeners and skins
with a maroon scotchbrite pad. I did a line at a time on the skin, and just
moved the same pieces of blue painters tape around. I'm frugal and that
tape is expensive! Clean it again with acetone.
Get the skin dimpled with the C-frame, and dimple the ribs and stiffeners with
the squeezer. I used the tank dimple dies and was very happy with the results.
More cleaning and then tape off the areas of the interior skin that you don't
want to get proseal on. First session with the sealant is just enough to
butter up the stiffener flanges. Cleco them onto the skin, make a fillet around
them with the end of a popsicle stick (bought a package of these at Michael's).
Let the sealant set up for a day, then come back and extract the clecos, dab a
tiny amount of sealant in the rivet hole with a toothpick and then place a
rivet in each hole, cover with rivet tape and back rivet. Be sure to clean
the rivets in MEK before rivetting. I had a terrible time trying to back rivet
these. Even using the pneumatic squeezer on the rivets near the edges was a
challenge with the slippery sealant.
After the stiffeners were rivetted, I covered every rivet head on the interior
with a good glob of sealant. I used a veterinary syringe as an applicator and
that worked great (local feed store had them for $1.99 each) ended up using 5
of them for the whole tank project. The sealant was easy to clean up out of the
syringe, just let it cure for a couple of days, then push it out with a pick
or thin screwdriver.
After the stiffeners are in, get the fuel drain and caps installed. Be sure
with the deluxe fuel caps to figure out the rivet lengths in advance. The
machined flange has differing thicknesses around it, and you also have the
vent line tab to deal with.
part of the build.
