Ran into my first possible issue with the empennage with HS404 and HS405
One one side i drilled the HS 404 a little to close, (and not on the centerline)
http://n830pe.wordpress.com/#jp-carousel-157
Its labor day so nobody at vans to ask, is this acceptable or do i need to get a new HS404?
I moved on to the other side, and did much better with the edge distances, however, one of the drills thru the spar is a little too close to the edge of the skin, so the rib sticks out a little. This is the one im really hoping isnt a big issue, because if i need to replace, ill ned to replace some spar parts too....![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
http://n830pe.wordpress.com/#jp-carousel-158
http://n830pe.wordpress.com/#jp-carousel-159
