tonyjohnson
Listers,
I am having difficulty with the installation of the main gear weldments on my 8A, and seek your advice.
I bought the project partially completed. The gear weldments are loosely in place. They cannot be fully removed because of the cap over the spar prevents them from being lifted up. The shims that are called for in the plans have been made, but not installed. There are two shims, one that goes between the main weldment and the F804A spar.
Page 30A, detail R-R shows the shim and indicates that it should be attached to the weldment with "double flush" rivets. I cannot find anything in the plans about how to do a "double flush" rivet. I coult not rivet the shim to the weldment in any case, since I cannot get the weldment out without drilling out the rivets that attach the cap across the tops of the F804A and F804B spars.
There is also apparently supposed to be a shim between the forward leg of the weldment and the F895 side pieces that mount against the skin. I did not see that shim on the plans, but I saw one on the website of an RV8A bulider, and one came with the kit from the previous builder.
The left weldment is pretty much lined up, but does not have the shims in place. The right weldment is not lined up. It needs to move outboard and down about 1/8 in.
Any suggestions would be appreciated.
Tony Johnson
RV8A Orlando
Tony Johnson
RV8A Orlando
