All,
I am in the process of fitting my flooring. I am having trouble with where the foreward section of the footwells "should" mount to a piece of angle that was riveted to the aft side of the 804 center section. That piece of angle is nowhere near level with the side ribs and the center ribs that support the outside of the footwells and the center flooring section. The angle on the 804 appears to be about .25" lower than the ribs. I thought I must have mis-located the angle on the 804 but it is where the drawing calls for it to be.
Anyone else had this problem? The only thing I can think to do is rivet a .25" shim to the angle. That is a heck of a shim!![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
