Getting to the point where we need to plan the electrics in the fuselage.
The 7 we already have was a little different - the plans related to the kit we had - as opposed to having a Mark 4 RV8 kit with Mark 1 instructions.........
We have decided on the basic fit:
10" Skyview inc Dynon TXP and 2 axis Autopilot.
Garmin 695 (we have no XM in Europe)
SL30 - to provide ILS to the Skyview
Intercom
Standby instruments as required by UK.
I am planning on taking the electrics down the right hand side, the pneumatics and flap electrics down the left.
Does anyone have diagrams, photos or links to help me in planning as I am nearly ready to get the turtle deck on and don't want to end up on my belly fitting things later.
ADAHRS is going on 2 ali angles just behind the rear baggage, probably locate the remote TXP on the same rails if I can.
Engine switches to right of panel, most switches will be switch breakers, any other cb's on a drop down front cover below the right console switches as per photos off the forum.
I think we are sorted, but just need a little inspiration and a gross error check from you guys
Intercom
