During trial fitting the throttle cable I have been unable to adjust it to reach complete travel. It seams to me the F-864E-1 bracket is too far aft. I have the fork end and jam nut threaded in all the way and the throttle arm hits idle slightly before the the cable limits out at idle. As you can see from the photo at full throttle the cable limits out before the throttle lever reaches max. I could make a new F-864E-1 and move it slightly forward but there isn’t much room for that. The other option is to omit F-864E-1 completely and attach the cable at the gear tower. The nut on the mixture cable will not sit perfectly flat and there is a possibility the cables will be too far forward.
![IMG_0501.jpeg IMG_0501.jpeg](https://vansairforce.net/data/attachments/46/46741-3fb780eb8a4e0771da5c6355128f07ca.jpg)
