AX-O
I am finishing my tail kit. Not much left however, it feels like the tail will never be finish
I ran into this problem (look at pic). Basically the arm on the elevators is about 1 1/16 of an inch longer than the HS skin. The Rod end bearings are installed per the plans. Did this happen to you? I am assuming that you just cut the HS skin (also fiberglass tip) and make it fit. My question is the following: How much distance do I need (for clearance when the elevator swings) between the end of the elevator arm and the end of the HS skin?
Second question:
Look at pic below. The plans say to cut a section on HS 609 to allow the elevator horns to swing down. Drawing 27A is referred for the measurement. After checking that drawing over and over, I can't figure out where the dimension is located. All I see is that the F-811D spacer/FWD elevator stop has a section that is 2 inches long. How much of HS609 should I cut? Right now I have the dimension at 2.5 inches. The 2 inches from the F811D spacer plus 1/4 inch for clearance. Does that work?
By the way, very proud of my tail kit
Second question:
