schmitty340
Active Member
I just finished my smoke system installation and would like to give a big thank you to Marvin over at Smoke Helpers!
I used his deep well tank made for the baggage compartment of the RV8. I ask him to weld the pump mounts right to the top of the tank, and the fit was perfect. The shut off solenoid and regulating valve were mounted to a plate I made mounted under the pump. This resulted in a removable package, if I ever need the space. With this setup, I still have full use of my fwd baggage compartment.
The firewall fwd was easy with the harware he supplied. Cut and fit some hoses, drill two holes in exhaust.(making sure one on each side) then secure the injectors with clamps. Finally secure the lines. Done!
![268404ed1ae18da7edef753c56ba71c0_zpswnrvzqoh.jpg](/proxy.php?image=http%3A%2F%2Fi1252.photobucket.com%2Falbums%2Fhh575%2Fschmitty3401%2F268404ed1ae18da7edef753c56ba71c0_zpswnrvzqoh.jpg&hash=bf68423eadd33705e4ac9395ca67b882)
![0d2fba8c607354db9591e854fbfe2144_zpsnxpqvu2c.jpg](/proxy.php?image=http%3A%2F%2Fi1252.photobucket.com%2Falbums%2Fhh575%2Fschmitty3401%2F0d2fba8c607354db9591e854fbfe2144_zpsnxpqvu2c.jpg&hash=f183b6e1ef1f5e369a55b52f24e3905c)
![fe63fa16ac28946512222aed0015acb3_zpskdyn3xat.jpg](/proxy.php?image=http%3A%2F%2Fi1252.photobucket.com%2Falbums%2Fhh575%2Fschmitty3401%2Ffe63fa16ac28946512222aed0015acb3_zpskdyn3xat.jpg&hash=0f21d9004f87e89253ab3f548f4096a8)
![25ae874fca9664a5aa6ad693caaf44f5_zpsv8zqmkc0.jpg](/proxy.php?image=http%3A%2F%2Fi1252.photobucket.com%2Falbums%2Fhh575%2Fschmitty3401%2F25ae874fca9664a5aa6ad693caaf44f5_zpsv8zqmkc0.jpg&hash=14ece674b3c729588e9f97a239b042ab)
![069fed546e32dd08eeb3fde8927a2c7e_zpse3eyxwhp.jpg](/proxy.php?image=http%3A%2F%2Fi1252.photobucket.com%2Falbums%2Fhh575%2Fschmitty3401%2F069fed546e32dd08eeb3fde8927a2c7e_zpse3eyxwhp.jpg&hash=be7ad85ec844453a1aaf2764fa619dc6)
