jbDC9
I think I've run into a snag while starting on the gear alignment; initially I used Vans method using 4 plumb bobs along the gear legs and measuring back to the tail... all 4 weights lined up perfectly and the distance from the outer weights to the tail was almost a perfect match; off by maybe 1/16", the manual allows 1/4." Problem is, the gear legs and U-803 attach brackets seem to be pretty far aft. I've attached a few pics, the first 3 show the left side; I have the 3/16" line marked and the U-805 wear plate is sitting on it, but the 803 bracket is a bit crooked as it straddles the gear leg. I don't wanna drill it like that since that'll mess up the bolt holes as the go into the WD-822 weldment inside the gear tower. Should I file/polish the gear leg or 803 bracket to make it line up with the 805 wear plate? The right side (last pic) lines up the 803/805s with the 3/16" line pretty well, but the whole assembly still seems to be a bit too far aft.
To double check the alignment measurements, I used an alternate method using 2 plumb bobs dropped from an alum. angle attached to each gear leg, then measured from each weight in to the fuse. centerline (as described by Steve Raddatz on Yahoo!Groups). The legs appear to be perfectly square from the measurements, but the leg and 803/805 still seem to be a bit far aft. Any ideas on where I might be screwed up?
Thanks!
John -8QB
Houston
Thanks!
John -8QB
Houston
