flickroll
I intend to mount my AFS magnetometers just forward of the 'static port bulkhead' in my -8, using a platform (2 aluminum angles really) mounted across the upper fuselage longerons. The panel is not square to this, so I'll need to make a mount for the magnetometer that makes up for this difference. Does anyone know what the tilt of the panel is relative to the upper fuselage longerons? I THINK it is 8 degrees, but then I found a post that said it is 8.5 degrees. Thanks
