RV-8 panel image file?
N546RV
Does anyone have or know where I can find a diagram-type image file of the RV-8 main panel section? I want to do some kind of idle looking at how I might lay out my panel, mostly to just help inform how I'm going to plumb the wings.
I've looked around a bit but found nothing useful yet.
The Van's Aircraft web site can be hard to navigate but look under Support | Downloads. Here's a direct link to a zipped DXF file. If you don't have AutoCad there are numerous free DXF-viewers; just ask for a recommendation.
BTW, double-check the height of the panel drawing. I vaguely remember that the bent area is shown contiguous with the actual "panel" space and makes it appear about an inch too tall. I could be wrong.
Joe
Joe
Awesome, thanks! What does it say about me that I go to Google and VAF before checking the Van's site when looking for something like this?
:D
I have a CorelDraw file I use for RV-8 Panel Design(s) - I've exported it to a JPG here - however, may be of use to anyone who wants a specialist file type not covered above. Let me know by [URL="[email protected]"]eMail[/URL] if you need a specific file format - CD exports to all sorts of things I do not understand. I'll clean off all the current insts as desired...
NB The Panel slightly changed in ~2007 with the -1 fuselage, likely only the PP holes positions.
