Has anyone had good luck with Vans manual aileron trim for the 8. Seen a lot of interior pictures none with the manual trim???
Ya I have it installed in my 8. It works fine, just slide the lever on the sidewall to balance out your fuel load. With the 8 it's always fuel load you are leveling since the rest of the plane should be balanced side to side. Of course you can also just burn from the heavy wing if you like to balance it too!
Here's a picture of the under seat portion of the install.
Aileron trim by Andy Karmy, on Flickr
