Take it from the rivet gun operator on Pilot8's project......some guys just want the fastback look.Retrofit to a flying airframe? I struggle with why. Under construction, sure.
The thought of retrofitting a fastback mod to a flying RV-8 came from a couple different angles during some hangar talk. Maybe it's education and recreation. Maybe it's a badly cracked slider aft canopy section that needs much work anyway. Maybe somebody just always wanted a fastback.
In any case, while thinking through this, I considered the idea of going the fastback slider configuration and leaving the existing windscreen/rollbar/boot cowl/fairing in place, and integrate only the back half of the fastback mod, aka Tom Clark's slider fastback.
My search yielded no good results so I posted the question here. Coincidentally, I stumbled upon a slider fastback at Sun n Fun (an initial build however). The builder has done a superb job building and the look is right. Great looking lines and appealing to the eye in the side view. There was a good number of stock kit parts in the build, both "stock" from Van's and "stock" from ShowPlanes. I was surprised at how much of the standard canopy frame was used.
So the discussion was really about getting the fastback mod onto a flying airplane in the least painful way. Thus far it appears uncharted territory.
My question is..... How much aircraft sheet metal work experience do you have? If you no or little experience, this mod would probably be way over your head. I say this, because unless you know what you are doing, once you remove that turtle-deck, you can introduce all sorts of errors if the mod is not done correctly. To my mind, you would probably need to build a fuselage jig and install the plane in it prior to removing the turtle-deck skin. Otherwise, you may very well end up with a fuselage which is no longer straight. The mod can be done, but NOT by a rookie.The thought of retrofitting a fastback mod to a flying RV-8 came from a couple different angles during some hangar talk. Maybe it's education and recreation. Maybe it's a badly cracked slider aft canopy section that needs much work anyway. Maybe somebody just always wanted a fastback.
Lots of maybe’s and probably’s in there. My original question remains. Since you asked, I built my airplane. You state “the mod can be done” … so tell us how.My question is..... How much aircraft sheet metal work experience do you have? If you no or little experience, this mod would probably be way over your head. I say this, because unless you know what you are doing, once you remove that turtle-deck, you can introduce all sorts of errors if the mod is not done correctly. To my mind, you would probably need to build a fuselage jig and install the plane in it prior to removing the turtle-deck skin. Otherwise, you may very well end up with a fuselage which is no longer straight. The mod can be done, but NOT by a rookie.
Fuselage jig? I didn’t need a fuselage jig when I built my fastback. Did you use one when you built your fastback?My question is..... How much aircraft sheet metal work experience do you have? If you no or little experience, this mod would probably be way over your head. I say this, because unless you know what you are doing, once you remove that turtle-deck, you can introduce all sorts of errors if the mod is not done correctly. To my mind, you would probably need to build a fuselage jig and install the plane in it prior to removing the turtle-deck skin. Otherwise, you may very well end up with a fuselage which is no longer straight. The mod can be done, but NOT by a rookie.
The showplanes kit comes with directions on how to install onto a finished 8 complete with lots of pics. I think you can download all of the install documentation from their website for free.Lots of maybe’s and probably’s in there. My original question remains. Since you asked, I built my airplane. You state “the mod can be done” … so tell us how.
That is useful information, thank you. I should have looked there.The showplanes kit comes with directions on how to install onto a finished 8 complete with lots of pics. I think you can download all of the install documentation from their website for free.
