I'm engrossed in the canopy skirt phase of my RV-8A construction and have run into a couple issues where I've found partial answers.
The first deals with forming (rolling) the skirts to get a better flat set against the fuselage and canopy rail. No heat, a little heat and more heat didn't produce a noticable bend in the curve. A lot of heat (from a heat gun), along with a lot of muscle, produced a small change. Question is, when applying localized heat to a large epoxy part like the canopy skirt - how much heat is too much? And what are the bad things that can happen?
Second, I'm aiming for a no-gap finish all around between the skirt and fus / canopy rail (I glued the canopy and will glue the skirt). I've got about a 1/16 inch gap along about 3-4 inches of the bottom of the left skirt, and 2-3 inches along the top. Is it ok to declare victory - or have folks actually gotten the thing to set flat all around?
Of course the devil's in the details - 95% of the time trying to fix the last 10% of the procedure.
