RV-8 Canopy Separation
Bill Phillips
Hello fellow 8 builders. I have finished the fiberglass tape around the windscreen Bezel. How do you separate the resin back from the electric tape masking the plexie? Seems struck together pretty well. Can't seem to get anything to slide in between. How did the "smart guys" do it? Thanks, Bill of Georgia
Bill, If I understand you correctly the resin (and perhaps cloth) overlaps the electrical tape. If so, do not try to remove the tape just yet. Use a small sanding block with some 120. Sand the overlap (which will remove it) and generally thin the edge of the epoxy/glass to the thickness of the tape.....then remove the tape.
