I?ve nearly completed my canopy save for installing the windscreen frame. The canopy is difficult to open without applying force simultaneously on both sides. When I finally install the windscreen frame it will be impossible to get my fingernails between the canopy and windscreen thus nearly impossible to open not to mention the impossibility of being on both sides of the canopy at once when single pilot. I?ve checked the Delrin block on the slider and it does not appear to bind or to be too tight. Clearly, however, the ski-jump on the forward slider is the culprit.
Have others encountered this issue and if so how did you deal with it.
Thx,
Don
Thx,
Don
