Carl Froehlich
Builder tip - I receive Matco brake calipers with my kit. The Matco is just different enough to make fit up a real pain if you have the Grove gear legs. They can be made to fit, but you will need to trim off just a little on the housing to clear the gear leg brake line AN fitting. Only a straight fitting will work, not the more typical 45 or 90 degree AN fittings. You will also have to trim the wheel pant mounting bracket, but that needs to be done regardless if you have the stock or Grove gear.
If you can, recommend finding out if you can order/exchange the Matco for the older Cleveland calipers.
