The manual says the F-712E tail tie-down bar should installed after the vertical stabilizer has been fitted to the fuselage. It seems a lot easier to rivet the tie-down bar to the F-712 bulkhead before even installing the bulkhead in the fuselage. Then later when installing the vertical stabilizer, I could drill the bolt holes through the whole assembly. Any reason not to do it that way?
