[email protected]
Member
I am in the final stages of planning the instrument panel for my RV 7A and I am looking for your input on the panel I have designed. Are there things I missed or should consider?
1. Mission short flights and cross country.
2. IFR capable.
3. Only glass panel no steam gauges.
Here are the switches:
Start L R Both Start
Master Power Alternator
Master Power Battery
Landing light
Taxi light
Navigation Lights
Strobes lights
Auxiary fuel pump
Pitot heat
Elevator trim
Flaps
Interior lights
Left seat warmer
Right seat warmer
Dimmer
Auto pilot disconnect (is this on Dynon panel?)
USB charging port (4x)
Master Avionics (this may not be needed with Vertical Power XP)
Here are the components:
Dynon SkyView Dual SkyView IFR
Engine Monitoring
Two-axis autopilot
SV-AP-Panel Autopilot Control Panel
SV-KNOB Panel AutoPilot Knobs
SV-COM Com
AOA/Pitot
Transponder
ADS-B In
Back-up battery
Navigation Mapping Software
Synthetic Vision
VP-X Certificatte
GPS Receiver
OAT Probe
D2 Pocket Panel or a D10A
Vertical Power VP-X Pro
Wire Harness Kt
Mounting tray
Garmin GTN 650
Comant Cl-122 COMANT VHF COMMUNICATIONS
Transponder Antenna
ADSB antenna
ELT 406AP
PS Engineering PMA5000EX
Thank you for your input,
2. IFR capable.
![nej33b.png](/proxy.php?image=http%3A%2F%2Fi60.tinypic.com%2Fnej33b.png&hash=93ae245580372da4c18e74dffc009051)
Landing light
Taxi light
Navigation Lights
Strobes lights
Auxiary fuel pump
Pitot heat
Elevator trim
Flaps
Interior lights
Left seat warmer
Right seat warmer
Dimmer
Engine Monitoring
Two-axis autopilot
SV-COM Com
AOA/Pitot
Transponder
ADS-B In
Back-up battery
Synthetic Vision
VP-X Certificatte
GPS Receiver
OAT Probe
Wire Harness Kt
Mounting tray
Garmin GTN 650
Transponder Antenna
ADSB antenna
ELT 406AP
