Anyone have a Sam James cowl and had cooling issues? What were the fixes in a nutshell that helped lower the temps??
RV-7A
Oil at 24/24 210-220
OAT 85
CHT 398 on #1,2,4 415 on #3
Feedback on CHT cooling? the only things I can think of right now is cutting the cowl scoop on the bottom back a bit to create a better exit, and siliconing the plenum (wanted to wait to inspect after the first flight). Any luck with trimming the cowl bottom? If so how far did you trim. Photos would be great!!
Thanks in advance!
RV-7A
OAT 85
Thanks in advance!
