Mike Coady
1. What is the ( AA6-125x1x1 ) material type that the aileron control stop is made of? I think It may be missing in my kit. Is it a channel? The print side view looks like it might be. It appears to be shaped somehow.
2. I have a Quickbuild. The aielrons are completed at the factory. When preparing to attach the inboard aileron bracket, the print shows the center AN3 bolt to go into a K1000-3 platenut. I can't see how I can attach the platenut. I am wondering if it was forgotten at the factory when building the ailerons. With the end enclosed already, the opening is only the size of a dime....how to buck if neccessary or can you just use a nut on this like the other two...What to do?
3. I have the flap braces and the aileron gap seals installed to the rear spar. Is it OK to go ahead and rivet the respective skin all the way into these two pieces now? The plans had only said rivet to the rear spar. I can't see why I should wait here.....any suggestions on proceeding?
thanks
thanks
