RV-7 tires work on RV-4?
AFulmer
Active Member
Lazy questions:
Recently purchased a flying RV4. Are my RV7 5.00-5 tires and tubes from Vans that I will not need for awhile the same as the 5.00-5 tires on the 4? They both are Type III, 6 ply rating, max load 1285 lbs.
And typical tire pressure to maintain in RV4?
yes and 32...
Yes, and I normally run at 32 psi. I don't let them go below 25 as the plane gets hard to push around...
FWIW.
John
