roadrunner20
I'm just buttoning up the bottom tail rear fuselage skin where I've attached the tail spring mount. The plans don't show leaving an access hole to enable you to remove the tail spring bolt without removing the skin. Have others added a hole with a plug to enable the tail spring removal? Seems like a no-brainer
