O.K. so I'm fitting my rudder pedals in the fuselage, drilled holes in the longerons for adjustment purposes as per Van's plans, turned out nice and neat; except, I'm a little concerned that there is not enough tube (Wd-6117 L/R) inserted into the rudder bearing blocks. They slide either way enough (left and right) that only about 1/8 " of the tube is in one side of the block. This is more pronounced at the aft setting because the side longerons taper out as the blocks are adjusted back.
Is this enough to keep the tube from sliding out of the block? Will it even be a factor? Thanks VAF expert builders.
Neal
Neal
