Rob Rickards
Active Member
Need help here please. The QB Flaps have the nut plate installed to receive the CM-4MS rod end bearing. The flap is complete so the bottom skin is on.
No way I can insert the CM- 4MS (90 degree) rod end bearing as the skin extension sits just below the hole.. Cant find any guidance on the plans or in VAF or other searches.
Every other puzzle, and they have been many. I have found an answer on this wonderful VAF
