Lou
Member
I think that I might be stuck on stupid.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Empennage - HS stab front spar - HS702/HS710/HS714 prior to bending
Page 6-1 under "Front Spar Assembly" step 2 - drill/match drill all holes inboard of the HS-404/HS-405 rib attach points. But a note on DWG 3 indicates that 4 of the holes "Enlarge/Drill 3/16 DIA in assembly with fuselage, 4 places" in view A-A.
Am I interpreting the step by step instructions too literally and I should drill all except those four 3/16" holes? I tried reading ahead to see where they might get drilled out at a later point, but my eyes started to cross as I went deeper and deeper into the instructions and could not figure it out.
I searched this site but it looks like everyone else sailed through these steps without a problem.
