The RV-6 and 7 use the same control stick and control column. The hinge brackets for the ailerons are also the same so all of the mechanical relationship is the same, just connected in a slightly different manner.
I believe the main reason for the change was to make the wing easier to build and reduce parts count (spar comes ready for mounting the brackets, No ribs to modify, etc.). The old bellcrank design may actually have an advantage in regards to maint. since it uses (I think) sealed bearings at the rotation point instead of a bronze style bushing that will wear over time.
I don't see any benefit to an RV-6 builder making this modification. Since the orig. purpose was to reduce construction time, he would just be trading the work to modify two wing ribs, for the work to modify most of the control system (all four push rod lengths custom made, bellcrank attachment to the spar web, etc.
Note that with the new style bellcrank installation on an RV-7/8 wing the tie down anchor was used as a spar web stiffener. It bridges between teh spar cap matterial on teh top and bottom of teh spar. This would also need to be incorporated if modifying the wing on a 6, which futher complicates the work involved.
Their is no real benefit to making this change (I do not believe it will change the control /handling qualities in any way) unless you are trying to drag out your wing construction as long as possible.
The weight is probably about a wash. It will cost more because you have to buy more parts.
My two cents...
