Is the emp kit the same for a 7 as it is for a 7A? Can a -7A EMP kit be used to build a -7?
P pilot28906 Well Known Member Mar 18, 2007 #1 Is the emp kit the same for a 7 as it is for a 7A? Can a -7A EMP kit be used to build a -7?
X xavierm Well Known Member Friend Mar 18, 2007 #2 Yes Yes, the 7/7A emp. kit is the same. You don't really have to decide between the 7 or 7a until you are ready to order the fuselage kit (per Vans)
cytoxin Well Known Member Mar 19, 2007 #3 the bottom hinge the bottom hinge gets drilled in a different spot for the tail dragger than the nose wheeler. two bolts are used to attach the stinger weldment.
