Installation of an auto fuel STC on a low compression 80/87 octane engine is an uncomplicated procedure. No major modifications are needed on this type of engine. We provide you with the paperwork and placards required by the FAA to make it all legal. An IA mechanic must "install" the STC by adding the new fuel placards and an engine placard. He then fills out a log book entry and form 337. The whole process takes approximately 30 minutes. No additional modification is required on this type of engine.
The same holds true generally for the higher compression Lycoming 0-360 and 0-320 engines depending upon the airframe in which they are installed. Generally speaking when these engines are mounted in an airframe equipped with a gravity feed fuel system (no fuel pumps), installation of the STC's consists only of paperwork and placards, with no modifications made. Some people then reason why buy an STC if it's only paperwork and placards. Installing the STC makes it possible for you to use an octane different than what was called for on the original Type Certificate while remaining in compliance with FAA regulations. Insurance companies expect you to be in compliance with the FAR's and we are able to contact you if we become aware of any changes in the fuel which could effect your airplane. Using auto fuel without an STC puts one in violation of FAR's: Part 43, App. A (2) (vi), 43.3 (a), 43.12.
In some airframes equipped with suction lift fuel systems (pump fed systems), different electric fuel pumps may need to be installed to insure adequate fuel flow, and/or the fuel pump locations must be moved. The STC for the PA-28-160, -161, -180, -181 requires the removal of the factory installed electric pump. This pump is replaced with two completely different pumps and a revised fuel system forward of the firewall. Installation on this airplane takes between four and six hours, approximately double that on 24 volt PA-28's. Click here for more info on the Piper PA-28, -160 thru -181
