chriscencula
Active Member
I'm building an RV-6A & would like to know if they are usually more tail-heavy or nose-heavy with a CS prop... I've got the old 0.016" rudder/elevator skins.
Firewall forward will be similar to the RV7 (battery in front of the F/W).
I'm asking because I've been thinking about 'building in' the option for a RV6-conversion at a later date & wondering about the extra weight of including the tailwheel weldment. An alternative would be to design a similar weldment that can be installed (bolted in) afterwards, but this would likely have to be two pieces instead of the one that attaches to both (612 & 611) bulkheads so it could be put in place without disassembling the tail.
Even if I don't do anything 'special' in terms of 6A-to-6 conversion options, it would be nice to have some idea ahead of time if the plane will likely be nose or tail-heavy with the C/S speed prop.
Chris
Chris
