I used to fly from a rather bumpy grass strip that would occasionally throw my 6A onto the tail tie down ring, and I have also landed tail first a couple of times. Both of these types of arrival tend to bend the tie down, Wd-627, back into the rudder bottom fairing. To stop the tie down bending so much (and nearly jamming the rudder) I added another bolt lower down the bracket, with a spacer to match the fin spar thickness and another large (~1" dia) washer on the fwd side of the frame. That was great for a while, but a couple of reasonably good whacks put the tie down back into the rudder
Yesterday I took the rudder off to fix the bottom fairing, and discovered my "fix" for the tie down was not such a great idea as the new bolt has tried to rip itself out of the frame - so looks like I will be replacing the frame as well. In fact most of the damage has probably been done when straightening out the bracket as the frame has bent rather than the bracket. I think the RV-7 type set up, with a screw in tie down ring is much better - although I will probably add some kind of abrasion strip on to the bottom of fuselage.
So I would suggest 6A builders use the 7A method for a tail tie down and 6A pilots leave the tie down bracket bolted to the fin spar and accept that it bends occasionally.
Pete
Pete
![frame%20damage2.jpg](/proxy.php?image=http%3A%2F%2Fwww.glosterairparts.co.uk%2Fframe%2520damage2.jpg&hash=f8a83aba27c0e8fe8bb5b7fdf7a8cb18)
