Assembling the nose wheel...The U623 Bushing is 0.004 smaller than the ID of the bearing, the wheel and bearing turns on the bushing rather than on the bearing race, even when the axle bolt is tightened to the point that the wheel can hardly be moved. Does this go away after use or does it require a fix. I thought about lightly knurling the U623 to swell it and then press it into the bearing.
Any one else have this problem ? Solutions ?
Bill
RV6-A Finishing...Ocala, Florida
Bill
