WingsOnWheels
I am in the process of riveting my top wing skin in place.
Per the drilling plan, I drilled the wing-walk area to #30 for -4 blind rivets (I realized later that -3 rivets are acceptable here also...). I would much rather use solid rivets if possible. Is there any reason not to use 426AD4 rivets here instead of the blind rivets. I know I will probably have to use some blind rivets on the lower skin if I can't get access to buck everything.
Has anyone used -4 rivets in the wingwalk area? Is there a better riveting order than: Top OB, Top IB, Bottom OB, Bottom IB?
