I purchased a flying RV-6 last summer so I am not the builder and have limited knowledge of aluminum construction, although I am learning.
I purchased a used Trutack Digitrak and Altrak autopilot that was installed in another plane. The servos were mounted on a thick pieces of aluminum.
My plan is to mount them per the Trutrak location under the co pilot seat pan. My question, what is the best method to fasten the stiffiner plate to the bottom skin of the fuselage. I was thinking I would countersink and thread the existing plate and dimple the bottom fuselage skin and use a flathead screw up from the bottom into the plate. I could then put a locknut on the screw from the inside. With this in mind, I need to dimple the bottom skin. How do you dimple the bottom skin without being able to get on btoh sides.
Any insight is much appreciated.
