anyone know the plan number that tells what bolt/nut is used to attach the shoulder harness cable to the shoulder harness cable attach plate. I believe the cable should swivel so therefore would require a castellated nut and a an4-x drilled shank, but I've been told that the plans call for a an4-xa bolt and nylon lock nut indicating to me that this will be bolted firmly in place not allowing the cable to swivel into position. thanks everyone
