I think the gear post needs a bit of clarification. It might not take the abuse of a C150/152, but it's still pretty tough (the nose gears on the 6A/9A might be somewhat of an exception). And the only time you'll have a problem with 'bucking' is if you land already fully stalled. The -4, at least, can actually be landed tail first in between 3 point & full stall, 'rolling' the tailwheel on, and settling onto the mains.
Wheelies are fine, but there's no reason to avoid either style landing. Practice both.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Conditions (or preference) can define which to choose. CG & flap position can make a bit of difference in which the plane 'prefers' (at least with the -4, which I have the most time in), but the pilot is still the boss.
Just ask the owner for a ride, & once you get to play with the stick/rudder, even in the air, you'll realize that you won't have any trouble with the plane. In my opinion (FWIW), you're in a better position to transition than a guy with lots of time in factory planes. You're still in training mode, and trying to learn. Guys with higher time in heavier feeling, slower reacting planes often have a harder time adjusting.
Charlie
