I friend has a older 6 that the rudder got damaged, the date on the rudder plans is 11-10-86 he did not build the plane and would like a new rudder. My queston is, could I use a pre punched skin, ribs, stiffeners etc ? I think I would have to use a non pre punched vertical spar and match drill the rod end holes using the old spar as a pattern. I think I would have to do this so the rod end bearings would match up with the with the vertical stabilizer ....any one have any comments or suggestions? Thanks
