Hi Guys,
I'm finishing an RV6 that another builder started. I decided to check the incidence of the HS and it is half a degree high in front. He had 1/4" spacer under the front spar. I can change it to zero easy enough, but will have to rework the fairing slightly. I have read other posts about their plane needing some nose down trim in cruise, and it seems that having the HS incidence a little high would provide that. Also, would it add some drag?
Question is, am I wasting my time sweating half a degree here? In the absence of any new information I'll just change it to zero incidence and rework the fairing.
Thanks for any input....
